professor95
Jun 14, 2011Explorer
olephart wrote:
Thank you. The Briggs belongs to a friend and he wants to do it, too. It will be easy to swap to a Champion when he comes to his senses.
I was planning to use a modified 3/8" T for the load block and make it just like your picture. That OK?
I plan to use 3/8" I.D. hose and fittings from the Load Block to the Copper tube. I'll limit the length to 12". I can use 1/2" hose if you think it is necessary.
Nope. For the engine size and length it sounds like you have it all figured out. You should be just fine.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
