professor95
Jun 15, 2011Explorer
olephart wrote:
Do you notice any difference in starting performance between drilled or adapted carbs?
Nope. You use the "primer" button on the Garretson low pressure regulator for a couple of seconds to put a little LP gas into the intake and then pull the rope. No need to use the carburetor choke either way. On my conversion in the "cave" of my fifth wheel I have electric start, electric prime and electric LP gas on/off via a solenoid valve. The genny easily starts from the inside control panel.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
