Cox89XJ
Jul 29, 2011Explorer
My Kenowa generator won’t put out any voltage. The last time I found a loose terminal, this time the exciter capacitor looks like it has blown out. Swelled up and leaking stuff out. It is a 24uf and 350 volt. Maybe I need to replace it with one with a metal case instead of plastic? I sure hope that fixes it. When I removed the gen cover I also noticed a little metal dust around the roller bearing. I believe I will replace that too while I have to torn down. Less than 100 hours and my hours of repair keep adding up????
