MrRchitty
Jul 30, 2011Explorer
I used a twist lock 30 amp with a small piece of 10 guage wire into a 4 inch box with 20amp receptacles and 20 amp rated switch. This combination allows me to attach to the higher rated 30 amp outlet on my Champion open synch 3500-4000 watt generator as well as the Champion twin inverter gensets into the parallel kit. I realize the limitations of the 20 amp rated switch with the 30 amp plug, however, it allows me the option to turn the power off or on when starting or stopping the generators without physically unplugging them. I am mindful of the load I apply to this pigtail assembly, and if it is something you do, you should do the same.
