professor95
Jul 31, 2011Explorer
Cox89XJ wrote:
My Kenowa generator won’t put out any voltage. The last time I found a loose terminal, this time the exciter capacitor looks like it has blown out. Swelled up and leaking stuff out. It is a 24uf and 350 volt. Maybe I need to replace it with one with a metal case instead of plastic? I sure hope that fixes it. When I removed the gen cover I also noticed a little metal dust around the roller bearing. I believe I will replace that too while I have to torn down. Less than 100 hours and my hours of repair keep adding up????
The capacitor is most likely your overall voltage regulator. Chinese generators typically offered capacitor regulation or an AVR. Of the two the AVR offered a more consistent regulation and lacked the "avalanche" midway in the waveform of capacitor regulation.
Unlike AVR failure sending output voltage sky high, failure of the capacitor simply killed output. Certainly a lot safer in the event of failure.
Capacitors do "age" and as they do the dielectric breaks down and the plates begin to puncture. Internal heat makes the case swell and if filled with oil it will begin leaking.
A metal capacitor will do the same thing. Once it begins to swell, it needs replacement. Just source a good quality non-polarized capacitor. The cost should be under $10 - not the $30+ dollars the genny manufacturer will quote you. Again - non-polarized, do not replace with a polarized electrolytic capacitor.
Metal dust around the roller bearings are not a good sign. The bearings were designed to be lifetime lubricated. Not sure what they consider as a lifetime but they can wear out, especially when operated in dusty or salt air environments.
Replacing a bearing is not always easy. In most situations it must be destroyed to remove and the new bearing will require a special driver or press to install so as to not ruin it.
Putting a few drops of oil on the bearing is not going to hurt. In fact, it might extend the life of your generator. ALL of these gennys need routine cleaning. I remove the louvered end cap and blow out dirt and dust with compressed air.
