MrRchitty
Sep 19, 2011Explorer
A transfer switch would disconnect all three wires from the street and connect all three wires from the generator to your panel. (I realize that you have four from the 240v plug, two hots, 1 common and 1 ground) If the common and ground bar are tied in your breaker box, mine use the same bus bar, then, yes, your generator's common (neutral) will no longer will be floating. I am not an electrician and have learned most of my stuff from a couple of co-workers who are electricians, however they can not tell me much about generators. That is where the professor comes in.
