professor95
Oct 22, 2011Explorer
Beach-Rat wrote:
SNIP
My design has the genny facing the 5er, hot muffler will be away from trailer and the heavy side of genny will be over the pinbox with the light side extending out front.. there will be 6in between genny and trailer wall.
Just made materials list today.
Will try and post pictures as it develops..
Have you run the measurements with the genny sitting longways to the fiver? This would point the muffler exhaust toward the truck cab (away from the fiver), give you access to the front panel and if you "flip" the recoil starter 180 degrees on the housing you will have a good down pull on the choke side to start.
Just brainstorming a little.......
Northern Virginia? Can't be too far from Richmond.
