professor95
Oct 25, 2011Explorer
I would add one additional piece of steel bracing. There is a considerable amount of stress from the "bounce" that will be experienced. IMHO you need a connection between the top and bottom steel "arms" other than the vertical pieces. Also, use grade 8 bolts where you attach to the pin box.
