RDMueller
Oct 29, 2011Explorer
This is the bottom of the floor piece. I screwed two 1x4s onto the bottom of the floor so it would be slightly raised, making it easier to get fingers under the box to move it around. Notice the patch covering a previous exhaust hole (more on that later).
Here you can see the previous hole from the top. I also had pieces of rubber that the gen would sit on to dampen vibration. I have since removed the rubber and covered the entire floor with carpet (easy to do since there is no longer an exhaust hole in the floor.
Here is the gen bolted to the floor. This is basically the current configuration except that as I said I now have the floor covered with carpet.
