tvsteve
Nov 13, 2011Explorer
MrWizard wrote:
sounds like the engine speed governor is sticky
try unbolting the gas tank, remove it, and do a thorough lube and clean of the governor lever at the top of the engine
also there is a very fine lite weight long spring connected parallel to the governor linkage to the carb throttle, that will cause "hunting" (speed variation) if the springs breaks
Inspected and lubed the linkage. It's free and not binding. Still, the problem persists. It's more of a slight misfire than a surging.
Steve
