MrRchitty
Mar 26, 2012Explorer
Has anyone tried to retrofit a starter on the Champion 46515 3500-4000 watt generator? It has the 196cc engine. I took the guards (air cooling covers) off to see if there were threaded holes to accommodate the starter.
The Champion 46555 has the same engine and comes with a starter. The pdf manual has a detailed diagram and the components which make up the charging and starting components are in purple.
What I noticed on my engine is there are holes present which are piloted, however, not drilled and tapped.
