MrWizard
Jul 01, 2012Moderator
based on my useage, i would estimate 1/3 gallon an hr when all i'm doing is charging batteries and using the laptop
thats 3 hrs per gallon not 8hrs per gal, using the 3k
when i had the 1200w, i got 5-6 hrs per tank while charging batteries and a few minutes of 1000w MW use, not 10hrs,
600w is an awful small amount of power,
i don't know how you could keep to that level unless all you did was use a portable battery charger set at 20-25 amps or less
I think you can buy the intelliguage from cpe parts
i have seen the wiring connection and its only 2 wires, that connect across the 120v line, its completely self contained, a real nice little gadget
call them , good luck
