professor95
Nov 28, 2012Explorer
JoshInReno wrote:
Cabela's had the 46516 on Black Friday sale with the wheel kit and cover for $279.99, normally $499.99. I waited 2 hours in the cold for that deal. :B
It is still in my garage in the box, but I'll get it assembled soon. I need to find an hour meter for it too.
Call CPE and order the 120 VAC tri-digital Intelligauge from the 46555 or 46539 for your unit. You can check a manual here that shows the gauge - look on page 6, item #6. It will give you hours, hz and voltage. It is not hard to add. If you need to know the "secret" to reset hours on the meter back to zero after oil changes I know what it is. CPE does not give out the reset info.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
