kirkadie
Dec 04, 2012Explorer
Thanks mrekim and prof.
I'll have to be patient and wait another hour or so for those west coasters to wake up before I can order it. Carb model is a bit different, but was in the manual.
Sorry if I ask perhaps a stupid question, especially after announcing on my first post that I'd try to keep quiet, BUT, what's the reason why I can't remove the main and idle jets and then connect the lp hose directly to the gasoline supply on the carb? Since the lp is already a vapor would it not fill the cavity (float bowl, etc) and still be pushed into the venturi at the same rate as the 'tube thru drilled out main jet oriface'...
thanks again,
Kirk
thanks again,
Kirk
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
