So
Sep 20, 2013Explorer
jmaotto wrote:It'd be genuinely helpful if you would tell us the make and model of both units you were coupling. And was the welder 120V or 240V?
I have the same Champion generator. Tried it on a Lincoln wire feed welder. As soon as I tried to strike an arc, it almost died. It could not take the surge.
By the numbers, a good condition 3500 Watt Champ should easily handle any 120Vac load which is rated for 120Vac/20A household circuit. Mine does.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
