Old___Slow
Sep 20, 2013Explorer
So wrote:jmaotto wrote:It'd be genuinely helpful if you would tell us the make and model of both units you were coupling. And was the welder 120V or 240V?
I have the same Champion generator. Tried it on a Lincoln wire feed welder. As soon as I tried to strike an arc, it almost died. It could not take the surge.
By the numbers, a good condition 3500 Watt Champ should easily handle any 120Vac load which is rated for 120Vac/20A household circuit. Mine does.
SO,
Just wondering? I looked at your 'Profile' not much info' ~ Others have seemly slipped into threads who have a agenda. I see your posts on '3000w Chinese Gensets info' all concerning Champion. What would you give as the true output of this 3500 Watt Champ you mention?
O$S
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
