anemic
Nov 12, 2013Explorer
I am actually favoring a vacuum pulse mikuni type pump fed off a vacuum port in the cylinder head. I got that idea from this thread. If you have successfully used this pump to feed a Champion generator I would love to hear your success story. thanks. My two questions are: can you find an existing vacuum port and were you able to draw from your MH fuel tank (which can be quite a distance of fuel line removed from the generator). For about 1/3 GPH flowrate, I'd prefer not to run a pump that is designed to push 18 GPH. I think I'll get better fuel economy, spend less money, and increase reliability if I can make this work.
(has nobody installed a Chinese generator in an open motorhome generator "box?")
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
