MrWizard
Nov 12, 2013Moderator
i think you will need a 'spacer' between the carb and the manifold intake
use the spacer to create a vacuum port to attach hose to run the pump
i read somewhere that SuperGen was bring out an extended run system for the cpe inverter gensets, using a similar pump
maybe that would be adaptible to your needs
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
