Nazih
Jan 15, 2014Explorer
Dear Professor95,
This is related to the installation of the electric start kit for Honda Engine. I purchased the same kit from the same supplier. I was reviewing your post, and found out a discrepancy that you might be able to assist or explain. The contents of the switch box "Does it contain all the components as shown in the picture you provided with the open box and the electric diagram or you added them?".
I received the same kit as in the ad but when I opened the key start box, there are no components (Charge coil Diode, Transition Diode and the 5 Amp fuse)! Did you add them to the kit or the kit came with these components? Are they required for a simple electric start for a Go Kart? Your feedback is appreciated.
Nazih
Nazih
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
