DPGBG
Aug 05, 2015Explorer
Gdetrailer. Yes sir I've seen that. Studied it for days. lol. Great info but for some reason mine will not work like that. Thanks though.
I do have the two whites that connect at the 240 plug.
I don't have an o scope but there is 4 wires coming out and I just can't figure why its not working. I'm beginning to think the AVR is stopping it however I can't see how. I mean I have two that are hot and two that are neutral. I can test them so I know which are which coil. That is easy enough to figure out and there is only so many ways you can hook them up. ??? I just don't get it. Something is keeping it from paralleling..
Wondering if the AVR has to see a neutral in the system for it to work??
I did meter it once without the neutral bond and the volts are high, red to white and black to white around 185 volts if I remember correct. So maybe that means the AVR needs the neutral to work. Without the neutral bond it seems like it's not controlling the voltage.
Any thoughts...
Any thoughts...
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
