DPGBG
Aug 05, 2015Explorer
Not touching at the head from what I can see. But I connect them together at the terminal block. I also tried jumping them at the block so not to connect them on top of each other.
To add.. If I leave stock wiring I get 120v from red to white, I get 120 volt from white to black, and 240 volt from red to black. However as soon as I remove the neutral bond. I get about 180 volt from red to white and black to white and I get nothing from red to black.
To me that seams like as soon as the neutral bond is broken the AVR is no longer controlling the voltage. Does that sound possible.
Without the neutral bond both coils are running unrelated and seem to be maxing out or uncontrolled.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
