MrWizard
Aug 05, 2015Moderator
and your mentioning this NOW ?
got a brand name, distributor ?
you do realize the feild coil is the rotor and carries less than 10amps
only about 4~5 amps is needed
the output 'Stator' windings are the heavy ones that produce the power
they are the ones that are mounted on the inside of the case
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
