MrWizard
Apr 23, 2016Moderator
Two things
First pull the end cap off the generator and then the brush holder for the feild brushes
They may be worn, stuck, or dirty
It they are OK put them back in
start the generator and using a volt meter on vdc setting
Measure the Volts on the wires to the brushes
If there is little to no voltage the avr automatic voltage regulator is bad
They don't cost very much from champion and you will get it or brushes in a couple of days directly from home office in Santa Fe springs, CA
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
