72cougarxr7
Feb 17, 2018Explorer
pianotuna wrote:
Hi,
What are the issues regarding the generator when stopping an inverter generator "under load"?72cougarxr7 wrote:
That being said, you just learned a costly lesson, a generator should never be started to shut off with a load on it.
Unplug the generator before starting or shutting off.
It is right in the owners manual for the generator (I have the same model).
"Never start or stop the generator with electrical devices plugged in or turned on"
I would imagine with an inverter, shutting off with a load applied would be less of an issue than starting with a load applied, but still something to avoid.
