Dufus's avatar
Dufus
50A male plug wiring
I am replacing the male end of the plug. Does it matter which post red and black are on i.e. does it have to be the same on the male and female plug as long as ground and neutral are correct?
thanks-
  • Dufus wrote:
    Thanks - my concern was when using a 30A pigtail will the camper see the voltage?
    The 30A pigtail is wired to both hot leads on the 50A end so it doesn't matter.
  • Thanks - my concern was when using a 30A pigtail will the camper see the voltage?
  • Interchangeable L1 -L2
    IN THEORY
    Determine which leg of your rig draws the highest wattage and feed that leg with the power feed L1 or L2 with the highest constant voltage.
    Freakin' nitpicking. But we nitpickers are helpless against it...
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
