opnspaces
Aug 24, 2020Navigator III
How are you measuring 4 gallons of hot water?
Check that your winterizing bypass valves are not partially bypassed. Also checked the outside shower and make sure the hot and cold knobs are off.
After that I would drain and flush the tank as it might be full of sediment and insulating the burner.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
