Old-Biscuit
Aug 25, 2020Explorer III
Cold Inlet diffuser (white) and Hot Outlet diffuser (black) are available for replacement on Suburban Water Heaters
Just disconnect water line.....then remove fitting screwed into tank.
Diffusers are replaced by pushing them in thru tank opening then held inplace via flange on end of diffuser and the fitting that is screwed back into tank
Suburban 171509...HOT (black) Diffuser
Suburban 171504... Cold (white) Diffuser
Atwood uses diffusers also but are NOT replaceable...factory installed
If Cold Inlet (points down) is broken off cold WILL mx with hot water and dilute it quickly
If Hot Outlet (points UP) is broken off Less HOT water will be available due to cold mixing with hot as it forces water out top outlet
Atwood doesn't even mention diffusers or have a real cutout picture of their tank components. Just a cartoon diagram
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
