- Itinerant1Explorer
BFL13 wrote:
Itinerant1 wrote:
The point being is best not give advice on something you don't understand or just guessing at. This is the regurgitation of bad info getting past as gospel. ;)
You can argue with Trojan then, since you seem to know more than they do.
"Balancing is performed when a parallel group of cells reaches a specified threshold voltage corresponding to almost
100% state-of-charge (SOC). At that point, the highest-charged cells “bleed down” a small amount to enable the remaining groups of cells to “catch up.”
( ISTR 3 tons was able to see that "bleed down" on his monitor, but others will have to confirm)
"At a voltage threshold slightly higher than the balancing point, a current interrupting device (contactor or FET array) will
open, stopping any charging current from flowing.....
" Even after the charger is unplugged, the battery may not be ready for use until it is allowed to balance for
approximately 10 minutes.....
Note: Once a set of batteries have achieved a balanced condition, they should remain balanced through normal use and charging. In order to keep batteries in balance and avoid over-discharge,
***** ensure that batteries not in storage receive a full charge weekly*** "
https://www.trojanbattery.com/pdf/Trillium_UsersGuide.pdf
What you stated in the post I responded to was this " I think the balancing can be observed on the Trimetric." now read my response again.
Even with the dropins that don't show individual cell voltages how do you know its truly taking place when all you see is pack voltages?
Copying and pasting shows your abailty to master computer functions but do you understand what you're pasting? - 3_tonsExplorer III
Note the curious pattern here whereby the aforementioned SiO2 Interlopers (non-LFP users) tirelessly search for ways to disparage their LFP competition - lol...What also puzzles me is why BFL (repeatedly using false constructs...) chooses to ‘block me’ instead of (when called out) simply addressing me straightforwardly and directly - there are numerous examples of this ill-spirited tactic... I have zero desire to block anyone, and don’t get why one would employ this tactic??
3 tons, open to considering ALL battery formats - jaycocreekExplorer IINot advice but I did see on the Victron smart shunt as my battery was charging with a Lifepo4 charger,it would get up to 14.4v then it would drop down to 13.6ish (don't remember exactly) then back up to 14.4v...It did this 3 or 4 times then the lifepo4 charger turned green and shut off.
I only "assume" it was balancing... - BFL13Explorer II
https://www.trojanbattery.com/pdf/Trillium_UsersGuide.pdf - Itinerant1ExplorerThe point being is best not give advice on something you don't understand or just guessing at. This is the regurgitation of bad info getting past as gospel. ;)
- BFL13Explorer II
Itinerant1 wrote:
You wouldn't know cell balancing is happening off a monitor that is showing just pack voltage other than it happens at x-voltage, bms's use individual cell voltages not pack voltages.
"If" you can see individual cell voltages you would be able to see the runners that should slow down after they reach the balancing voltage while the slower cells catch-up.
ISTR 3 tons (before I blocked him) describing how he can see his LFP balancing act on his Victron monitor, but can't remember what he was observing it doing. So I ASSume that (whatever it is) could be seen on a Trimetric
time2roll said: "LFP balancing is automatic when convenient. No need to make a deliberate effort."
The LFP guides say to get to full every so often and get them balanced. So if you haven't done it past their suggested intervals, then that would require a deliberate effort to do one.
Beats me how you know you are getting it done if it doesn't show on the monitor. You LFP guys can sort that out. - StirCrazyModerator
jaycocreek wrote:
In an actual capacity test with a heat gun,Will only got 1156 watt hours or 93+ amp hours out of the Battleborn 100ah battery..I only posted because someone here keeps saying Battleborn is 120ah but test clearly show it is not...
ya it is deciving also, when he did his tear down of a battleborn he said the cells added up to more than 100 ah, in his capacity test the bms shut off the battery at 107 ah ( believe if my old memory is remembering the right video) and he figures that was the limit they had it set for. it gets confusing when you have a BMS that ou can set for shut off points and charg limits because a draw down test wont tell you the actual AH of the physical battery but only what the settings will let you use.
Steve - StirCrazyModerator
pianotuna wrote:
I'm sure Stircrazy would subscribe to this view point--but BattleBorn deliberately derates their 100 amp-hour to 100 from a "real" 120 amp-hour.
So far as I am aware the rest of the Li makers don't protect the end user this way.
Could it be the battery management systems are keeping the bottom 20% from being used?
I know some are, it may be to protect the bottom end, but lets talk about this.. people are misconceving why you would want to do that. there are two reasons that stand out in my mind.
1 at a 100% depth of discharge the life span on LFP seams to be 3000 to 4000 cycles depending on the manufacture and format, still a long time. by limiting your usage to what people are thinking as the bottom and top you can raise that cycle life time to 6000 to 8000 cycles. and one more thing about the cycle life span of LFP its not like a LA battery where after you hit the cycle life san the battery is pretty much useless and only holds a surface charge, a LFP after it cycles out will still have 80% of the original capacity and will hold that for a long long time unless you physicly damage the battery, which is why you can buy used cells very cheep if you happy with 80% of the capacity.
this leads directly into the second reason a company could be doing this, by building 20% more into the battery if some one is very hard on a battery it will maintain the rated capacity after it cycles out and no one can come back on them and say your 100ah battery only puts out 80ah.
I think I have stated before its all to do with limiting there warenty exposure.
Steve - LFP balancing is automatic when convenient. No need to make a deliberate effort.
Little to no thought is needed compared to lead-acid. - Itinerant1ExplorerYou wouldn't know cell balancing is happening off a monitor that is showing just pack voltage other than it happens at x-voltage, bms's use individual cell voltages not pack voltages.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
