Slownsy
Mar 16, 2018Explorer
6V deep cycle batteries
Have had som very overcast weather the last 4 days, batteries down to 82% in morning back to 95% afternoon, how long can this be don before a 100% recharge becomes essential.
Frank
Frank
Almot wrote:
Bogart current - 30A max - comes from Bogart.
Almot wrote:
Lawrosa - inverter fridges draw "less" energy daily than on-off machines. But 12 cu.ft (or is it 13?) is a lot to cool, you can't trick physics.
Though not important in this particular situation - low overcast - but his 600W solar is not 60A system. Bogart PWM add-on to Trimetric monitor is 30A max. It does have limiting circuitry that allows over-panelling up to 600W without going up in smoke - as I recall - but it can't do more than 30A.
MEXICOWANDERER wrote:
When you know your ravioli, you know how long to keep it in the oven and at what temperature, to make sure it comes out just right.
It's a SMART oven. It has no adjustment. It knows how *IT* wants your ravioli to be prepared. There's no way in the world you would EVER GET burned ravioli, right?
This is how stupid smart battery charging is...
Get the parallel here?
Slownsy wrote:
TM-2030 Trimetric absorb 14.5 Amp set pt 2% 520A. time 4h high V15.9. float V13.5 Overcharge 10%. Finish A 3.5%
Solar 600W I am running a domestic 314l Samsung inverter fridge. Overnight all op usage around 14-16% 80A. As my generator was stolen I just wanted to check how long without damaging batteries. Back on a powered site for now. Thanks all.
Frank.
Note on P7: This selects which of two standards is used for the TM-2030 to register when the battery is "charged". L3 or L4
If L3 is chosen: this is the "easier" condition: It will cause the green "charging" light to flash (indicating "meets charging parameters") when the voltage exceeds P1 value, and simultaneously the charging amps is less than P2 % times P3. The green light will stop flashing as soon as this standard is not being met. In this case the green flashing light means "batteries presently meet charged criteria."
If L4 is chosen: a higher standard is required to be "charged." First the L3 standard must be met. Then next the overcharge percentage in P20 must also be met before the green "charging" light will flash. It will then continue to flash until the "Percent Full" display goes to 97% or lower. In this case the green flashing light means "batteries were charged and they haven’t yet discharged below 98% full."
