mikakuja
Nov 14, 2017Explorer
7 pin wiring into 2005 Fleetwood TT
We are working on a 05 Fleetwood Wilderness and need some help with the wiring. At the main wiring junction where the 7 pin wiring enters under the front of the trailer there are two relays that are wired together into the trailer. It appears that the 12v from the 7 pin wiring may have been wired to these at some point but has been disconnected and we are not sure of the correct way to re-wire it. I am not sure if the rest of the relays are wired correctly or not as the trailer has been extensively rebuilt on the front.. Currently there is no 12v connected from the TV but everything in the trailer otherwise works as it should. The trailer has 260w of solar so 12v from the TV is not a huge deal, but it would be nice to have everything wired correctly... Does anyone have any knowledge of how these relays should be wired, or even pics of your current wiring may be able to help us to figure out how to re wire the relays.
Thanks
I'll try to get some pics of the wiring and post them when I am at the trailer.
Thanks
