Flyfasteddie
Feb 03, 2016Explorer
When you say you used carb cleaner, is that the spray-on type stuff? If spraying that in the carb caused more problems then the carb sounds like the issue.
If it were me, the first thing I'd do is run some Seafoam or Berryman B12 through it. If your issue is carb related, this should help at least a little, and maybe a lot.
Sorry to hear about your cat. Losing those little guys is rough.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
