Artum_Snowbird
Feb 03, 2016Explorer
You might try just turning up the idle speed a bit. If that keeps you going, then it's likely a jet in the carb that allows only a trickle of gas through might be plugging. If you can get to the adjustments, find the low speed jet and carefully screw in, counting the turns, then turn out again to the same spot.
It's kinda like electrical sometimes. Move and jiggle, then put back to exactly the same spot and see if it works better.
Do the same with the plug wires, checking each end, before you spend any money. If you get to the plugs, they could be out of gap too, and that would make it come to a halt easier than normal for sure. Set them right before you spend money on new ones if you have the time but no money unless it's obvious they are well worn.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
