TucsonJim
Feb 03, 2016Explorer II
I've rebuilt over 100 Toyota carbs in my days as a mechanic. Here's an easy check on this one:
With the engine shut off, remove the air cleaner. While looking down on the carburetor, grab the top and give a firm rotational twist to the carb in both directions. If you see any movement the screws between the baseplate, the mid-body or the top of the carb have become loose. This would cause the kind of symptoms you are seeing, and is a common problem. The solution is to remove the carburetor, and tighten up the screws between the sections.
If you're in the Tucson area, I'd be happy to check it out for you.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
