Tom_M1
Feb 03, 2016Explorer
I had a similar problem. If it's the same as mine, the carburetor has two accelerator pumps. One is mechanical and the other is vacuum. The diaphragm in the vacuum actuated pump disintegrated and allowed raw gas to be sucked through the vacuum hose into the intake manifold making the engine run very rich. I pulled the hose off the diaphragm and plugged the end of the hose. This cured the problem. I don't know what the vacuum pump is for, but I didn't notice any difference in performance.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
