j-d
Feb 04, 2016Explorer II
Picking up on what Tom_M said... We had an '88 Mitsubishi pickup with a Mikuni carburetor with a diaphragm that broke apart and caused us problems. It was long enough ago that there was still a shop with "Carburetor" in its name and a man there who knew something about...carburetors. Sold me the part and told me how to install it. I remember it was what I'll call "external to the carb itself." I didn't have to take the carb off or even that far apart, to install the new diaphragm.
That Mitsu had a clear plastic fuel filter. Easy to inspect for water and debris, Cheap to buy, Simple to replace.
I found the fuel filter and a part called "Choke Pull-Off" on rockauto.com looking at 1983 Toyota Pickup 2.4L-4cyl. Filter looked just like the one on the Mitsu. The Pull-Off that looked like a diaphragm with a rod coming out of it reminded me of what I put in the Mitsu. I know it says "Choke" and not "Pump." The carb specialist told me that a failed one causes a leak that causes problems by misdirecting either Fuel or Vacuum (and I forget which, this was 15-years ago).
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
