dougrainer wrote:
Old-Biscuit wrote:
So you are still using the iii limit switch (190*F) vs the correct ii limit switch (130*F)?????
ii & iii use SAME size orifice ---31,000btu #52
ii & iii use different size motors but same air/combustion wheels (CFM)
Get the correct Limit Switch, 130°, Atwood 35132
Your heat exchanger is NOT designed for that 190*F temp (iii limit switch)
8531 uses a 190 limit. Where do you get 130 limit for this model type? Doug
8531-ii uses a 130*F limit switch (same for 16 thru 35 btu
ii)
8531-iii uses a 190*F limit switch (same for 16 thru 31
iii & IV)
Simple check of PARTS List for the TWO different versions----
ii vs iii
