Mfee2079's avatar
Mfee2079
97 Ford 460 issues
I have a 97 Fleetwood pace arrow vision on the Ford F53 chassis with the 460 v8 gas engine.
33k miles on rig. New aluminum 80 gallon fuel tank and FoMoCo sourced fuel pump. After driving for roughly 2 hours I lose power and can't get over 2k rpms without the engine bucking and shaking, if I continue the check engine light will come on.
If I shut off the engine for a minute or more all is normal again after restart though for how long varies.
I did have a problem with the distributer bolt being loose and the timing getting messed up which I set as well as I could as due to the design of the dog house I can't get anywhere near seeing the timing marks without putting my face into a spinning fan blade. If anyone has a suggestion on how to fix that issue also I'd appreciate it.
Oh before anyone asks the rig is OBD1 even though it's a 97 so pulling a code without the check engine light on doesn't work
  • Guess is it’s fuel delivery. Did it do it before the new fuel pump?
    sucks to do a 2 hr test drive but I’d hook a fuel pressure gauge to it and see if fo drops when the symptoms start.
    Possible heat soak issue with the ECM or pump etc. Not common and hard to diagnose if it’s the ECM. I’d look at fuel pressure first.
    good luck!
    • nehuge6348's avatar
      nehuge6348
      ECM is located inside the vehicle behind the brake pedal.  Doesn't get heat soaked there.
  • My 94 460 did that after 180,000 miles.  It had the original plug  wires hahahaaa.  Replaced them and problem was solved.
    Over the years I have changed plugs every 40-60K miles and the fuel filter.  Did the rotor and cap at about 100,000.
    Good luck,
    Jim.
      nehuge6348
      So Jim, your 460 motorhome went 180,000 miles?  Or do you have a truck that did?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
