chiefward's avatar
chiefward
A/C compressor will not shut off
My grandson and family are living in my Dutchman 5th wheel while their house is being repaired from hurricane Michael damage. Last night he called and told me the a/c compressor does not shut off after the fan shuts down. He is manually flipping the breaker to cut it off at night. Any suggestions on what to look for in figuring out what's going on..( i'm in Covington, GA., the trailer is in Lynn Haven, FL)
  • Mine did that. That relay is/was an integral part of the circuit board that was accessible from inside the trailer.
    I put a new board in and all was well,
  • Thanks for the information. Will pass this information on to my grandson. He is quite talented in all things mechanical.
  • Yes, the relay is fused. IMO, this happens when running on marginal 120 volt supply and the heat build up causing arc'ing and then the contac fuses shut. Doug
  • I second the comment that it sounds like the compressor relay contacts are welded closed.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    One thought.. on SOME units (Heat pumps) it is normal for the compressor to run for a BRIEF time after blower shut down.. Like 30 seconds.
  • I've had it happen on two different units. Both were the compressor relay.
    It could be the thermostat also. If you disconnect the compressor wire on the back of the thermostat you will know which is the problem.
    The relays are cheap if you can solder, otherwise it would require the whole control board.
  • Chris Bryant wrote:
    The relay on the circuit board is welded closed- he can try whacking it sharply, but it probably needs replacing.
    This is more then likely the problem. From on top of the rig at the AC unit you can jump the two thermostat wires to get the unit to run. then un jumper them to get the unit to shut off. If the unit still runs then look at the relay on the board. if it shuts down after you remove the jump then Thermostat.
  • The relay on the circuit board is welded closed- he can try whacking it sharply, but it probably needs replacing.
  • Sounds like a bad thermostat - might consider replacing - should be able to find a suitable replacement at any Big Box store. Lots of threads discussing how to replace thermostat.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
