Dutch_12078
Aug 15, 2013Explorer III
Two common possibilities... The roof unit may be too loose on the gasket, allowing condensate to drip through after it runs out of the drip pan drains onto the roof. The fix for that is to simply tighten the bolts from inside the RV to compress the gasket more. Be careful not to over tighten them though. The second possibility is that the drip pan drains are plugged, causing condensate water to run down into the inside panel instead of draining out on the roof. Cleaning the drains will cure that problem.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
