NEOK
Aug 08, 2019Explorer
A/C on 116 volts?
I just pulled into a site and EMS only shows 116 volts. Would you trust it to run 10,500btu AC unit for one night without doing damage go the unit?
Thanks
Thanks
RoyB wrote:
I have one of these RV120VAC VOLTMETER (AMAZON) installed in one of my AC receptacles to alow me to watch the AC VOLTAGE all the time... This has the GREEN SCALE on it for easy viewing...
Google image
Roy Ken
theoldwizard1 wrote:
That is well within the specifications in the US, as long as it does not drop to far when the AC is starting.
LittleBill wrote:is the important point. If you see 108V with the compressor off, it will likely drop below that when it starts & runs.
108v and higher and your good while running
