bdpreece
Aug 15, 2019Explorer II
If you are even semi handy you can adjust them yourself. When one of my cables was hanging loose I was sure it was broke so I ordered the cable and the correct tool to cut it and crimp the end on from Amazon. What actually happened on mine was the lock nuts on the adjustment posts came loose and allowed the adjustment nut to loosen up. After getting them adjusted I applied a drop of loctite blue to each nut so that wont happen again, The adjustments are outlined in the service manual. Start HERE and then after reading click on service manual.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
