dougrainer
Apr 13, 2014Nomad
RJsfishin wrote:wa8yxm wrote:
You need to re-think and then ask the question of yourself again.
You said "I have 4 six volt batteries"
No, you do not
You have two two piece 12 volt batteries.
Now, The quesiton becomes
I have 2 12 volt batteries in parallel, Can I add a 3rd, and the answer is: YES
That is really sad when you have only 1 correct answer (above) out of all these !!
Yes, in the REAL sense, you CAN add a 12 volt to a 6 volt bank. BUT, as I pointed out, it will NOT function correctly and at its optimum performance. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
