Ron_KritonExplorerJan 17, 2014Adding a 30 A connection to my 50 A 2014 CougarSince I like to heat with a 1500 watt heater while hooked up to 50 Amp, I have trouble with using other high draw appliances also. Most 50A pedestals also have a 30A outlet. I know I can add a 30A h...Show More
Broccoli1ExplorerJan 17, 2014YOU SHOULD HAVE PLENTY OF POWER AS MENTIONED. THIS IS HOW THE RV POWER BREAKS DOWN
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connectionsAdding power outlets in slide with no wiringCougar 22rbswe Satelliite ConnectionKeystone Cougar Propane quick connect question
