LarryJM
Jan 17, 2014Explorer II
Ron Kriton wrote:
Thanks for all the input. Just have to figure out which outlets connect to which breaker.
You should also determine which applicances such as microwave, WH, A/C, converter, might also share the same ckt as an outlet(s). Not that common AFAIK, but should check and document anyway. Also, a good idea is to do the same with the 12V ckts for like lights and what fuzes since once you have a problem then is not the time to do the research.
Larry
