You_can_t_take_'s avatar
Oct 06, 2015
Adding a battery charge line...
After 2 nights at Yellowstone my coach battery went dead. Checked for voltage from the starting battery with the engine running and the volt meter connected to the positive lead of the coach battery (after disconnecting it from the coach battery and did not get any reading at all... 0 volts). That tells me that there is no charge line from the starting battery to the coach battery when I'm driving. My other fifth wheels etc. all had a charge line in the 7 pin connectors. Obviously this small motorhome has nothing like that :( So.. is there anyone out there who has added a charge line from the starting battery to the coach battery... and if there is.. can you tell me what size wiring I should use, what size fuse I should place in the line and whether it is worth it to put in a diode to prevent current from feeding back into the starting battery when I am connected to shore power?? I will also add a switch so that I can isolate the starting battery from the coach circuits (so I don't have to bother my fellow campers to get a boost start every time I use too much power)!! Short version.. charge line from starting battery positive post to coach battery positive terminal with switch and fuse and maybe a diode.. Thanks for any info. I am currently 6 days into a 30 day trip and need to correct this issue soon!! Thanks again!!
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
