dougrainer
Jan 18, 2014Nomad
MEXICOWANDERER wrote:
OPINION
I had an OEM Norcold ice maker and had nothing but problems with it. I was using DISTILLED water and the idiot tech adviser at Norcold claimed that was the problem the ice maker had all the problems. Water would not flow to fill, the mechanism would not defrost. I yanked it out by its roots.
Dometic and Norcold Icemakers are the exact same as in residential refers. The problem with installing is both Dometic and Norcold have a disclaimer from adding a Icemaker. But you can add one. You just have to drill the fill spout hole and mount the icemaker in the freezer and connect the Icemaker wire harness and install the water valve solenoid. For your money, I would find space and install a U line RV Icemaker. either the b 195 or the sp 18. Doug
http://www.u-line.com/products/marine-rv.html
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
