wa8yxm
Jan 18, 2014Explorer III
Pirate wrote:
Anyone ever add an aftermarket ice maker to a Norcold unit that doesn't have one? Any reason you couldn't do it? Thanks.
Couldn't no.. Shouldn't yes.
If you want one I have most of one I'll give you.. And with a bit or work we can pull the wiring harness and water solenoid as well.
My Dometic came with one, Both companies use the same product line for their ice makers, No significant difference.. It was a bit of a PITA, and what's more.. IT finally failed (The water line from the solenoid to the ice tray split.. I'd replace it save read on)
Well.. I replaced it originally with 4 Rubbermaid ice cube trays.. now down to two cause,, These two make ice faster than I can use it.
The Ice Maker.. Was not so swift.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
