mena661
Dec 21, 2014Explorer
jcarlilesiu wrote:I and others have essentially done this. It is the simplest way to get it done. The complexity just increases from there. The way to make it brainless while in use is a transfer switch on the circuit you want to have on inverter. Not possible unless I want to rip out walls in my case.
Is the better option adding an inverter with a dedicated female 30 amp outlet on the side of the rv near the front where the batteries are, and simply plug the shore power cable into the inverter when needed?
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
