time2roll
Dec 23, 2014Nomad
http://www.xantrex.com/power-products/power-inverters/pro-series-inverters.aspx
That is modified sine wave that could cause trouble with coffee maker electronic controls and I have heard Apple products don't like the MSW. Most things do work fine on MSW. I recommend SW because everything works as designed.
If the 120v power run is long consider a separate transfer switch so you do not have to pull wire both ways.
Initial post was about small items... coffee maker is about 800 to 1500 watts depending on model. So a little more involved pulling wire.
I recommend a small transfer switch for each branch circuit you want powered vs the additional sub panel you mentioned above.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
