deppeler
Jan 05, 2015Explorer
Ron3rd wrote:jcarlilesiu wrote:
I would like to add an additional battery (have one group 27 now), possibly a solar charging system and an inverter.
I hate that the 120V outlets don't work on battery power. Seems crazy you can't charge a cell phone.
Anyway, I would like to an an inverter. My goal would be to wire it into the system with an automatic transfer switch for shore power/battery power.
Seems awfully involved.
Is the better option adding an inverter with a dedicated female 30 amp outlet on the side of the rv near the front where the batteries are, and simply plug the shore power cable into the inverter when needed?
Seems easy enough, but not "clean". I would really rather add an inverter and transfer switch. Has anybody one that that can explain the process? Does the converter need to stay? Can it go? If the converter is removed, how do the 12V outlets and lights and water pump run? Will they run off of battery power without the converter when on shore power?
Im confused about that one aspect.
Wiring it to the outside with the 30a Receptacle is how I do it and several other members on this forum are doing the same. I power all my outlets with a 300w Samlex inverter, but only use it for the TV's. Works great.
Just remember to switch off your charger, etc as pianotuna noted above.
This is what I want to do...do you have a picture of what it looks like plugged in (to itself) from outside the TT?
